I’m trying to convert a string value from an nginx JSON log to a double value. The raw message is as follows:
{"remote_addr": "127.0.0.1", "certificate_subject": "", "remote_user": "reverse-proxy", "time_local": "25/Jul/2022:14:01:19 +0000", "request": "POST /api/v1/access/auth HTTP/1.1", "status": "200", "body_bytes_sent": "1656", "http_referrer": "", "http_user_agent": "lua-resty-http/0.08 (Lua) ngx_lua/10011", "request_id": "fdcf14b7-e812-4f3c-aa62-4d374a85b91e", "request_length": "482", "request_time": "0.011", "upstream_addr": "192.168.3.33:14871", "upstream_response_time": 0.012, "pipe": ".", "ssl_protocol": "", "ssl_cipher": ""}
The value in question is “upstream_acces_time”. I have defined a rule as follows:
rule “Convert to Double”
true
let converted_double = to_double($message.upstream_response_time, 987.6);
set_field(“upstream_response_time_converted”, converted_double);
(The default value is there for debug purposes)
But looking as the stream message, I only get the following result:
Notice that the “converted” field contains the default value of 987.6 as defined in the rule and not the converted value of the original field. This is the case for all messages.
- Graylog version 4.3.2
- JDK: Oracle Corporation 1.8.0_162 on Linux 4.15.0-189-generic
The nginx messages are converted using the extractor:
"title": "Nginx JSON access log",
"extractor_type": "json",
"converters": [],
"order": 0,
"cursor_strategy": "copy",
"source_field": "message",
"target_field": "",
"extractor_config": {
"flatten": false,
"list_separator": ",",
"kv_separator": "=",
"key_prefix": "",
"key_separator": "_",
"replace_key_whitespace": false,
"key_whitespace_replacement": "_"
I have run the same message throw the simulator to see if I get any helpful messages. But it shows the same result:
Is my rule correct, or what am I doing wrong?
How/where can I get more helpful message that point out what is going wrong?
