Hello everyone!
Previously I encountered an error: gl2_processing_error (Replaced invalid timestamp value in message)
I solved this by converting the date. But if leave this one condition with the conversion, then the message will not be parsed (usually I used default json put there us a gl2_processing_error)
I added lines to parse the json message and when I run the simulation the rules are fine. All fields are laid out. But when I go to the stream and open any log, I just have only a whole message and a timestamp field there
Here is my rule:
`rule "replace timestamp"
true
let result = regex("([0-9]{4}-[0-9]{2}-[0-9]{2}T[0-9]{2}:[0-9]{2}:[0-9]{2}.[0-9]{9}Z)", to_string($message.message));
let new_date = parse_date(to_string(result["0"]), "yyyy-MM-dd'T'HH:mm:ss.SSSSSSSSS'Z'","UTC");
set_field("timestamp", new_date);
let json_parsed = parse_json(to_string($message.message));
set_fields(to_map(json_parsed));
end`
So ever so often the way pipelines see data is different than how it ends up being stored in opensearch. You might want to try the debug function and look in server.log to just make sure its proper json when it hits the pipeline.
Also i tend to prefer flatten_json as it seems to give me less challenges.
[PipelineInterpreter] Error evaluating action for rule <replace timestamp/null> in pipeline <dummyPipeline/stage 0> with message: source: null
(Error: In call to function 'parse_date' at 6:19 an exception was thrown: Invalid format: "")
Rule <replace timestamp> Unable to parse JSON
com.fasterxml.jackson.core.JsonParseException: Unrecognized token 'INFO': was expecting (JSON String, Number, Array, Object or token 'null', 'true' or 'false')
I`ve rewrited my rule:
true
let result = regex("([0-9]{4}-[0-9]{2}-[0-9]{2}T[0-9]{2}:[0-9]{2}:[0-9]{2}.[0-9]{9}Z)", to_string($message.timestamp));
And try to only parse message:
rule "message parser"
true
