I’m using the free version of Graylog and running into an issue. Pensando is sending its output to Graylog, but often there are 3 log entries combined into a single message.
I’ve tried several things (with pipelines), but I can’t manage to split them correctly. As a result, I also can’t apply extractors effectively.
Does anyone have an idea how I can fix this?
Here’s an example of what the message looks like:
switch1 switch1[1410]: 2025-07-16T05:55:19Z,flow_delete,allow,c574ab42-ab87-462f-8302-99d2a05babfd,10.32.12.20,49635,10.32.14.117,9080,6,1002,00000000-0000-0000-0000-000000000000,15,3141,11,5453,3314,DSS,DL.10.15.1020,VN48LYG01C,a852.d4f5.fa80,2,v3,false,from-uplink,NA,tcp_rst,tst-domain,1,0,0
2025-07-16T05:55:19Z,flow_delete,allow,c574ab42-ab87-462f-8302-99d2a05babfd,10.32.14.16,20830,10.32.14.116,2380,6,3146110,00000000-0000-0000-0000-000000000000,1,82,1,68,3314,DSS,DL.10.15.1020,VN48LYG01C,a852.d4f5.fa80,2,v3,false,from-uplink,NA,tcp_rst,tst-domain,1,0,0
2025-07-16T05:55:19Z,flow_delete,allow,c574ab42-ab87-462f-8302-99d2a05babfd,10.32.14.16,20829,10.32.14.116,2380,6,2622417,00000000-0000-0000-0000-000000000000,1,82,1,68,3314,DSS,DL.10.15.1020,VN48LYG01C,a852.d4f5.fa80,2,v3,false,from-uplink,NA,tcp_rst,tst-domain,1,0,0
