Multiline logs in Graylog
Hi Graylog Community,
I have the following scenario:
fluent bit sending logs to Graylog using GELF output plugin, my fluent bit configuration already include multiline, the issue that I currently have is that in Graylog the multiline logs is showed line by line, I’m trying to get it as it showed in the pod (app actually is running on EKS), I’m wondering if is there any workaround or missing configuration from my end, I will appreciate any comments in advance.
Regards.
