Palo Alto Networks Input
Import 9.1json without logs to graylog server
Ask Need to build a syslog server? Or through this out-of-the-box method
You shouldn’t need to build a separate syslog server, you can have the PaloAlto send directly to the Graylog server you put the input on.
Hello
What @tmacgbay said, located here.
