I came across Graylog for the first time today, and was interested to see it in action. I tried an install on OpenVZ using Centos 7 Minimal.
Base graylog install failed, because Java is not installed by default… Might be good to add that to the SPEC file as a dependency to have it automagically added… but that was a minor issue. As per the below, it looks like the graylog unit file is trying to start a service that is masked on OpenVZ. Is there an actuals reason for this dependency? Is it required?
Feb 16 21:45:57 logger systemd: graylog-server.service holdoff time over, scheduling restart.
Feb 16 21:45:57 logger systemd: Cannot add dependency job for unit systemd-vconsole-setup.service, ignoring: Unit is masked.
Feb 16 21:45:57 logger systemd: Stopped Graylog server.
Feb 16 21:45:57 logger systemd: Started Graylog server.
Feb 16 21:45:59 logger systemd: graylog-server.service: main process exited, code=exited, status=1/FAILURE
Feb 16 21:45:59 logger systemd: Unit graylog-server.service entered failed state.
Feb 16 21:45:59 logger systemd: graylog-server.service failed.
