Problem when installing graylog
Hello Friends; I hope you are doing well
I have a problem with the installation of my new graylog server
the service won’t start, and i can’t reach the GUI from my pc to the server
this is the message
root@srv-log:/etc/graylog/server# systemctl status graylog-server
Loaded: loaded (/lib/systemd/system/graylog-server.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Sat 2021-07-10 14:16:49 UTC; 5s ago
Docs: htt8p://docs.graylog.org/
Process: 6337 ExecStart=/usr/share/graylog-server/bin/graylog-server (code=exited, status=1/FAILURE)
Main PID: 6337 (code=exited, status=1/FAILURE)
In below all configuration changes that i made in server.conf
password_secret = A*********
#root_username = admin
root_password_sha2 = 1185fb1546044737330a2a6d5455d24afb31176f5dfa09f8c4750ce7dbe9056ceb28a8
root_timezone = UTC
#Default: 127.0.0.1:9000
http_publish_uri = http://0.0.0.0:9000/
http_external_uri = 0.0.0.0:9000
Thnak you
Regards
Your bind address needs to be specific i.e. the IP of the Graylog server HTTP interface.
https://docs.graylog.org/en/latest/pages/configuration/web_interface.html#configuration-options
Is it possible to see you whole graylog configuration file?
If you do post it could you use the editor in Markdown.
format-markdown
Thanks :slight_smile:
Just an idea for troubleshooting,
Is Elasticsearch servIce enabled and running correct? Also how about MongDb service?
Example of my Graylog server using http
Graylog_Config
is_master = true
password_secret =epOqmLi7r7CdZxl76QOQxr8bRUPYstNdcBuajsaSNfG5bkXXFxyHAAsdgmCfyHhSKlKXjMQG9ojc0bn22EBT17elgGTUJgbD
root_password_sha2 =272c3ac6b26a795a4244d8d2caf1d19a072fbc1c88d497ba1df7fef0a4171ea6
root_email = "greg.smith@domain.com"
http_bind_address = 10.10.10.10:9000
http_enable_cors = true
elasticsearch_hosts = http://10.10.10.10:9200
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
elasticsearch_index_optimization_timeout = 1h
output_batch_size = 5000
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
message_journal_max_size = 12gb
mongodb_uri = mongodb://localhost:27017/graylog
http_connect_timeout = 10s
Hey there @abouhoun , just as a note, the biggest thing that would help here (given that we’re dealing with a log management software) is the logs. Can you upload those as well?
@abouhoun aside from what everyone else also mentioned, please change http_external_uri to http://192.168.5.101 (or whatever IP address you have assigned to your machine)
Please let us know if that works.
Hello dear friends , yes exactly the problem was with http_external_uri ,
it’s fixed
Thank you
