Graylog isnt working
I’ve completed the installation process but I’m unable to access the interface and when I run ‘systemctl status graylog-server’, I get the following input:
Loaded: loaded (/usr/lib/systemd/system/graylog-server.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Fri 2019-02-22 12:14:01 UTC; 5s ago
Docs: http://docs.graylog.org/
Process: 23443 ExecStart=/usr/share/graylog-server/bin/graylog-server (code=exited, status=1/FAILURE)
Main PID: 23443 (code=exited, status=1/FAILURE)
Feb 22 12:14:01 ip-172-31-19-79 systemd[1]: graylog-server.service: Main process exited, code=exited, status=1/FAILURE
Feb 22 12:14:01 ip-172-31-19-79 systemd[1]: graylog-server.service: Failed with result ‘exit-code’.
What does server log say?
http://docs.graylog.org/en/3.0/pages/configuration/file_location.html
