OIDC authentication and claims
Description of your problem
It doesn’t appear to be possible to specify required claims for OIDC authentication. This is critical when using Google authentication to prevent other users (from other organizations) from logging in. This is done using the hd: claim (OpenID Connect  |  Sign in with Google  |  Google for Developers).
Description of steps you’ve taken to attempt to solve the issue
I’ve tested the authentication mechanism and Google does not require a relevant domain.
Environmental information
Graylog 4.2.0+5adccc3
Operating system information
  • CentOS 7
Hi @ceeceegee, I’d recommend raising this in the Github project: GitHub - Graylog2/graylog2-server: Free and open source log management. Our developers are engaged over there and should be able to help out with addressing the issue you’re seeing with the OIDC integration.
Great, thanks! I’ve raised a feature request now: OIDC claim support missing in Graylog Enterprise · Issue #11528 · Graylog2/graylog2-server · GitHub
