Notification grace period - bugfix
NotificationGracePeriodService.inGracePeriod() method does not update cache if lastEventTime.isPresent() is true, but the period is over.
I would suggest the following change:
public boolean inGracePeriod(EventDefinition definition, String notificationId, Event event) {
    if (definition.notificationSettings().gracePeriodMs() <= 0) {
        return false;
    final Optional<DateTime> lastEventTime = get(definition.id(), notificationId, event.toDto().key());
    final boolean isInGracePeriod = lastEventTime.isPresent() ?
            lastEventTime.get().isAfter(event.getEventTimestamp().minus(definition.notificationSettings().gracePeriodMs())) :
            false;
    put(definition.id(), notificationId, event.toDto().key(), event.getEventTimestamp());
    return isInGracePeriod;
Regards,
SM
do you mind opening a pull request over at github?
feel free to do anything you like.
i just solved my problem.
ср, 6 мая 2020 г., 17:23 Jan Doberstein via Graylog Community <graylog@discoursemail.com>:
Thank you @sergei.melnichenko for the fix. :slight_smile:
You can track it’s progress here: https://github.com/Graylog2/graylog2-server/pull/8067
