Not able to get logs
i have setup graylog version 2.4.0, using graylog default docker compose.
after that i setup sidecar for getting logs using file beat.
how i can enable port 5044 ( logstash ) in graylog server ? i have not installed any logstash service as per the documentation. Please help.
i think i am not able get the logs due to this.
You have to create a Beats input in Graylog (System/Inputs) and expose the port of the Docker container.
thanks alot jochen. that solved the problem :slight_smile:
