Hi Im newbie in Graylog, I was installed Graylog in Kubernetes as Helm chart (packaged with Mongodb) with Fluent as Log Collector and OpenSearch too.
All pods running well until service pod give the external ip and port for Graylog dashboard, Then first thing I did is setup input with GELF UDP. That GELF UDP input runs but still give me 0 msg/s minute average rate of throughput.
Finally, I check the dashboard and try to search index with 5 minutes timerange and this problem happened.
Elasticsearch exception [type=index_not_found_exception,reason=no such index]
OS Information:
AWS EKS (Kubernetes 1.29) for Graylog, Mongodb and Fluentd Apps.
VM OS Ubuntu 20.04 for OpenSearch version 1.3.14. -
Package Version:
OS Information:
AWS EKS (Kubernetes 1.29):
Graylog version 5.2.5 with Helm chart version 2.3.5
Fluentd version 1.16.2-debian-graylog-1.0
Mongodb version 6.0.4-debian-11-r0 -
VM OS Ubuntu 20.04:
OpenSearch v1.3.14 -
Graylog Helm Chart version 2.3.5 without OpenSearch, and Fluentd version 1.16.2-debian-graylog-1.0.
Cluster network Inbound already opened for All traffic and Graylog + MongoDB port.
Cluster network Outbound already opened for All traffic and Graylog + OpenSearch port.
Check Curl in OS: works
Check Graylog pods logs: works
Check Fluentd pods logs: works
Googling already done too but still cant find the same problem.
I wish the community can give me enlightment with this failed indexing or reference me a better version instead of what Ive used. Thank You so much!!
