graylog_Index_error
We recently had a power outage in our office and since the reboot, Graylog is throwing the below error
I tried recalculating the index manually and even rotated the active write index manually no luck can someone help me on this if they had any similar problem?
Index not found for query: graylog_0. Try recalculating your index ranges.
at org.graylog2.indexer.cluster.jest.JestUtils.buildIndexNotFoundException(JestUtils.java:134) ~[graylog.jar:?]
at org.graylog2.indexer.cluster.jest.JestUtils.specificException(JestUtils.java:96) ~[graylog.jar:?]
at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:60) ~[graylog.jar:?]
at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:65) ~[graylog.jar:?]
at org.graylog.events.search.MoreSearch.scrollQuery(MoreSearch.java:273) ~[graylog.jar:?]
at org.graylog.events.processor.aggregation.AggregationEventProcessor.filterSearch(AggregationEventProcessor.java:210) ~[graylog.jar:?]
at org.graylog.events.processor.aggregation.AggregationEventProcessor.createEvents(AggregationEventProcessor.java:121) ~[graylog.jar:?]
at org.graylog.events.processor.EventProcessorEngine.execute(EventProcessorEngine.java:92) ~[graylog.jar:?]
@kvenkat971
Maybe I can help.
What do you get after executing these?
curl http://localhost:9200/_cat/indices
If there is a problem execute this and it should tell you whats wrong.
curl -XGET http://localhost:9200/_cluster/allocation/explain?pretty
Hope that helps
I got the output for the cat indices and I can’t see graylog_0 in their
This is the output for the second command
“index” : “filebeat-6.1.1-2018.06.28”,
“shard” : 2,
“primary” : false,
“current_state” : “unassigned”,
“unassigned_info” : {
“reason” : “CLUSTER_RECOVERED”,
“at” : “2021-06-17T07:19:34.913Z”,
“last_allocation_status” : “no_attempt”
“can_allocate” : “no”,
“allocate_explanation” : “cannot allocate because allocation is not permitted to any of the nodes”,
“node_allocation_decisions” : [
“node_id” : “AWg1Gxp1QraOR4CZrc3cNg”,
“node_name” : “AWg1Gxp”,
“transport_address” : “...:9300”,
“node_decision” : “no”,
“deciders” : [
“decider” : “same_shard”,
“decision” : “NO”,
“explanation” : “the shard cannot be allocated to the same node on which a copy of the shard already exists [[filebeat-6.1.1-2018.06.28][2], node[AWg1Gxp1QraOR4CZrc3cNg], [P], s[STARTED], a[id=ztWVQI-PSE25GIiwYZkE9A]]”
looks like the problem got fixed, I can see the logs on the dashboard now, not sure what happened though
