Couldn't find index
I have a working graylog server with 2 elastic node which configured as a cluster.
Few days back I got following error
“ERROR [MessageCountRotationStrategy] Unknown index, cannot perform rotation
org.graylog2.indexer.IndexNotFoundException: Couldn’t find index graylog_3034”
and currently no logs were write to elasticsearch cluster. all logs in buffer are dropping
below are the proper log file for references
2019-11-13T08:58:35.565+05:30 ERROR [MessageCountRotationStrategy] Unknown index, cannot perform rotation
at org.graylog2.indexer.indices.Indices.numberOfMessages(Indices.java:192) ~[graylog.jar:?]
at org.graylog2.indexer.rotation.strategies.MessageCountRotationStrategy.shouldRotate(MessageCountRotationStrategy.java:66) ~[graylog.jar:?]
at org.graylog2.indexer.rotation.strategies.MessageCountRotationStrategy.shouldRotate(MessageCountRotationStrategy.java:34) ~[graylog.jar:?]
at org.graylog2.indexer.rotation.strategies.AbstractRotationStrategy.rotate(AbstractRotationStrategy.java:65) ~[graylog.jar:?]
at org.graylog2.periodical.IndexRotationThread.checkForRotation(IndexRotationThread.java:113) ~[graylog.jar:?]
at org.graylog2.periodical.IndexRotationThread.lambda$doRun$0(IndexRotationThread.java:77) ~[graylog.jar:?]
at java.lang.Iterable.forEach(Iterable.java:75) [?:1.8.0_232]
at org.graylog2.periodical.IndexRotationThread.doRun(IndexRotationThread.java:73) [graylog.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_232]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:1.8.0_232]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_232]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:1.8.0_232]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_232]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_232]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_232]
it looks like graylog has in the configuration (mongodb) the information that the current index is graylog_3034 but that us not present in elasticsearch anymore.
could you run a manual index rotation? System > indices > index name > maintenance > rotate active write index
Does that help?
I just delete the last index which is graylog_3034 and restart the graylog server. Issue has been resolved
