You mention the docker container is crashing but there are no elasticsearch logs. Are there any docker container logs indicating where the problem may lie?
Why did i not think of that!!! now i feel stupid
i didn’t note down the ID of the container last it ran so i have restarted the elsaticsearch continer and will wait for it to crash again and then see if i can find something in the docker logs.
but isn’t it wierd that there are elasticsearch logs inside the container?
I found this in the log when i started my elasticsearch container up again:
Blockquote
[2020-06-30T05:12:55,783][ERROR][o.e.ExceptionsHelper ] [ikLmw4q] fatal error
at org.elasticsearch.ExceptionsHelper.lambda$maybeDieOnAnotherThread$2(ExceptionsHelper.java:280)
at java.base/java.util.Optional.ifPresent(Optional.java:183)
at org.elasticsearch.ExceptionsHelper.maybeDieOnAnotherThread(ExceptionsHelper.java:270)
at org.elasticsearch.http.netty4.Netty4HttpRequestHandler.exceptionCaught(Netty4HttpRequestHandler.java:176)
at io.netty.channel.AbstractChannelHandlerContext.invokeExceptionCaught(AbstractChannelHandlerContext.java:285)
at io.netty.channel.AbstractChannelHandlerContext.notifyHandlerException(AbstractChannelHandlerContext.java:856)
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:364)
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:348)
at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:340)
at org.elasticsearch.http.netty4.pipelining.HttpPipeliningHandler.channelRead(HttpPipeliningHandler.java:68)
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:362)
at io.netty.handler.codec.MessageToMessageDecoder.channelRead(MessageToMessageDecoder.java:102)
at io.netty.handler.codec.MessageToMessageCodec.channelRead(MessageToMessageCodec.java:111)
at io.netty.handler.codec.ByteToMessageDecoder.fireChannelRead(ByteToMessageDecoder.java:323)
at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:297)
at io.netty.handler.timeout.IdleStateHandler.channelRead(IdleStateHandler.java:286)
at io.netty.channel.ChannelInboundHandlerAdapter.channelRead(ChannelInboundHandlerAdapter.java:86)
at io.netty.channel.DefaultChannelPipeline$HeadContext.channelRead(DefaultChannelPipeline.java:1434)
at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:965)
at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:163)
at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:656)
at io.netty.channel.nio.NioEventLoop.processSelectedKeysPlain(NioEventLoop.java:556)
at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:510)
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:470)
at io.netty.util.concurrent.SingleThreadEventExecutor$5.run(SingleThreadEventExecutor.java:909)
at java.base/java.lang.Thread.run(Thread.java:835)
im not sure if that could be the issue im facing?
I need to stress though that the server ran out of discspace so the error above could be related to that
