New installation no web gui
hello
i just newly installed Graylog with this guide
http://docs.graylog.org/en/2.4/pages/installation/os/debian.html
on a new VM with debian 9 / 4GB RAM and 300GB DIsk
installation worked well - but can’t access the Webinterface
on this step
To be able to connect to Graylog you should set rest_listen_uri and web_listen_uri to the public host name or a public IP address of the machine you can connect to.
for rest_listen_uri and web_listen_uri i did add my private IP 10.10.250.40 - i only need acces in the LAN
is this wrong?
have a nice day
vinc
What’s the complete configuration of your Graylog node?
What’s the network environment it’s running in?
@jochen
found out the Problem - the password had to be more then 16 caracters.
Merci for your help
vinc
