Need help on slookup plugin
Hi team,
I am working on slookup function and unable to understand the logic and request somone’s help on. I understand this is used for comparing two field from differnt streams and if found rtnField.
Here is my scenario -
I have stream 1 - Contains clientipaddr field [with stream ID 5b9e7ef0c4445a03714dfe81
I have stream 2 - Contains SourceIPaddr and SourceUsername [Stream ID 5c8e511a52622402c9b6bb75]
Now I need to rtnfield SourceUsernname if match found in “clientipaddr” & “SourceIPaddr”
Here is the function I wrote but unable to understand which stream this needs to attach to.
rule “Find and Insert User”
has_field(“clientipaddr”)
let user_name = slookup(“5c8e511a52622402c9b6bb75”,sourceAddress,clientipaddr,[“sourceUserName”],“14400”,“dec”);
set field(“userName”,“to_string”(user_name));
OR
has_field(“auth_status”)
let user_name = slookup(“5b9e7ef0c4445a03714dfe81”,sourceAddress,clientipaddr,[“sourceUserName”],“14400”,“dec”);
Stream ID mentioned in slookup function is sourceStream or from where it is looked up from?
Please help
he @blason
didn’t you hang around long enough here to know that formatting the post helps others to help you? Use Code blocks around your rules is the easiest task …
In addition you should page @billmurrin as he is the author. You should mention also your Graylog version and the plugin version you are using …
My bad!! Let me take care of this from next time for sure.
@billmurrin - Any help would be really appreciated.
Thanks for the help. I manged to resolve it. Infact here are the functions
First Stream ID = Is the remote stream ID
Source Field = The field where the pipeline is attached to
Destination Field = Field from remote stream
Rtn Field = the Field yo would like to return from remote field
Its really fantastic plugin @billmurrin
