Graylog pipeline rule: Lookup multi-value fields not populating
I currently have the following pipeline rule which does a multi field lookup:
rule "Network VPN Enrich"
contains(
value: to_string($message."Network_EventName"),
search: "SSL"
OR
contains(
search: "VPN"
rename_field(
old_field : "srcip",
new_field : "VPN_SRC_IP"
let output_2 = lookup(
lookup_table : "geolookup",
key : "VPN_SRC_IP"
“The rule basically looks up a multi-value field using VPN SRC_IP. The ‘geolookup’ lookup table returns:”
"single_value": "29.7212,-95.3626",
"multi_value": {
"continent": {
"code": "NA",
"geoname_id": 6255149,
"names": {
"pt-BR": "América do Norte",
"ja": "北アメリカ",
"ru": "Северная Америка",
"de": "Nordamerika",
"es": "Norteamérica",
"fr": "Amérique du Nord",
"zh-CN": "北美洲",
"en": "North America"
"country": {
"confidence": null,
"geoname_id": 6252001,
"is_in_european_union": false,
"iso_code": "US",
"names": {
"pt-BR": "EUA",
"ja": "アメリカ",
"ru": "США",
"de": "USA",
"es": "Estados Unidos",
"fr": "États-Unis",
"zh-CN": "美国",
"en": "United States"
"traits": {
"autonomous_system_number": null,
"autonomous_system_organization": null,
"connection_type": null,
"domain": null,
"ip_address": "168.5.20.120",
"is_anonymous": false,
"is_anonymous_vpn": false,
"is_anycast": false,
"is_hosting_provider": false,
"is_legitimate_proxy": false,
"is_public_proxy": false,
"is_residential_proxy": false,
"is_tor_exit_node": false,
"ip_risk_snapshot": null,
"isp": null,
"mobile_country_code": null,
"mobile_network_code": null,
"network": "168.5.16.0/20",
"organization": null,
"user_type": null,
"user_count": null,
"static_ip_score": null
"city": {
"confidence": null,
"geoname_id": 4699066,
"names": {
"en": "Houston",
"zh-CN": "休斯敦",
"fr": "Houston",
"ja": "ヒューストン",
"ru": "Хьюстон",
"pt-BR": "Houston",
"de": "Houston"
"represented_country": {
"confidence": null,
"geoname_id": null,
"iso_code": null,
"names": {},
"type": null
"coordinates": "29.7212,-95.3626",
"location": {
"accuracy_radius": 20,
"average_income": null,
"latitude": 29.7212,
"longitude": -95.3626,
"population_density": null,
"time_zone": "America/Chicago"
"postal": {
"code": "77004",
"confidence": null
"registered_country": {
"confidence": null,
"iso_code": "US",
"names": {
"pt-BR": "EUA",
"ja": "アメリカ",
"ru": "США",
"de": "USA",
"fr": "États-Unis",
"zh-CN": "美国",
"subdivisions": [
"confidence": null,
"geoname_id": 4736286,
"iso_code": "TX",
"names": {
"pt-BR": "Texas",
"ja": "テキサス州",
"ru": "Техас",
"de": "Texas",
"es": "Texas",
"fr": "Texas",
"zh-CN": "得克萨斯州",
"en": "Texas"
"string_list_value": null,
"has_error": false,
"ttl": 9223372036854775807
For some reason the multi value fields are not populating from the pipeline testing:
Actions Output
$output_2: {“value”:null}
Is there something I missing?
