Is it possible that the Graylog server listens to several IP addresses? Because our LoadBalancer sends every single log_level to an IP address?
Graylog Version: 5.2.2
Opensearch Version: 2.11.1
Thanks in advance
Thanks in advance
as i remember old version can not remember, if you bind 0.0.0.0 it listen all the IP and Interface available i guess.
Graylog could do this, but I don’t think there is a need to. The docs say
“There is no need to have multiple entries for the same host because a single entry covers the syslog level that is defined, plus all other levels that are of higher priority. So, you only need to include one entry with the lowest level priority required.”
So you only need one entry with one IP and the lowest level of message you want sent.
