Hey there,
I’m currently running a Graylog OVA and everything is smooth, perfect.
I would like to add a second nodes to my project however I can’t seem to be able to find proper documentation on the subject.
Could anyone be able to help me a little bit?
I’m currently running two OVA and my goal is to make the node from the second OVA accessible in the first OVA.
To my understanding, from reading the config files it should be simple. But somehow I can’t get the second node to show up.
Is the following the only line to change in the graylog.config files?
# The URI will be published in the cluster discovery APIs, so that other Graylog nodes will be able to find and connect to this Graylog node.
# This configuration setting must not contain a wildcard address!
http_publish_uri = http://x.x.x.x:9000/ (Proper ip here)
Please, help a noob out
