Multi Node Graylog Setup problem
Dear all, I’m trying to build a 3 node GL cluster but have some strange logs and cant bring it up.
My cluster is using GL 2.5 / EL 5.5 / Mongo 4.0.6. No firewall, no SELinux
IPs :
node01.local 172.23.88.9
node02.local 172.23.88.10
node03.local 172.23.88.11
Mongo DB / Primary Config
rs0:PRIMARY> rs.config()
“_id” : “rs0”,
“version” : 3,
“protocolVersion” : NumberLong(1),
“writeConcernMajorityJournalDefault” : true,
“members” : [
“_id” : 0,
“host” : “node01.local:27017”,
“arbiterOnly” : false,
“buildIndexes” : true,
“hidden” : false,
“priority” : 1,
“tags” : {
		"slaveDelay" : NumberLong(0),
		"votes" : 1
		"_id" : 1,
		"host" : "node02.local:27017",
		"arbiterOnly" : false,
		"buildIndexes" : true,
		"hidden" : false,
		"priority" : 1,
		"tags" : {
		"votes" : 1
		"_id" : 2,
		"host" : "node03.local:27017",
		"hidden" : false,
		"priority" : 1,
		"tags" : {
		"votes" : 1
"settings" : {
	"chainingAllowed" : true,
	"heartbeatIntervalMillis" : 2000,
	"heartbeatTimeoutSecs" : 10,
	"electionTimeoutMillis" : 10000,
	"catchUpTimeoutMillis" : -1,
	"catchUpTakeoverDelayMillis" : 30000,
	"getLastErrorModes" : {
	"getLastErrorDefaults" : {
		"w" : 1,
		"wtimeout" : 0
	"replicaSetId" : ObjectId("5c7f9b9d2cd4ee245aee4df5")
MongoDB Secondary server view :
rs0:SECONDARY> rs.slaveOk()
rs0:SECONDARY> db.printSlaveReplicationInfo()
source: node02.local:27017
syncedTo: Wed Mar 06 2019 13:28:31 GMT+0300
-1 secs (0 hrs) behind the primary
source: node03.local:27017
syncedTo: Wed Mar 06 2019 13:28:30 GMT+0300
0 secs (0 hrs) behind the primary
rs0:SECONDARY> show dbs
admin 0.000GB
config 0.000GB
graylog 0.001GB
local 0.000GB
graylog.conf file
rest_listen_uri = http://node01.local:9000/api/
rest_transport_uri = http://node01.local:9000/api/
web_listen_uri = http://node01.local:9000/
elasticsearch_hosts = http://node01.local:9200,http://node02.local:9200,http://node03.local:9200
#mongodb://graylog:123456@node01.local:27017,node02.local:27017,node03.local:27017/graylog?replicaSet=rs0
mongodb://node01.local:27017,node02.local:27017,node03.local:27017/graylog?replicaSet=rs0
graylog node 01 graylog.log file
019-03-06T13:11:19.455+03:00 INFO [Version] HV000001: Hibernate Validator 5.1.3.Final
2019-03-06T13:11:23.842+03:00 INFO [InputBufferImpl] Message journal is enabled.
2019-03-06T13:11:23.879+03:00 INFO [NodeId] Node ID: 8f49d4e6-5d90-4c10-906f-7324ad14c678
2019-03-06T13:11:24.245+03:00 INFO [LogManager] Loading logs.
2019-03-06T13:11:24.375+03:00 INFO [LogManager] Logs loading complete.
2019-03-06T13:11:24.376+03:00 INFO [KafkaJournal] Initialized Kafka based journal at /data/graylog/journal
2019-03-06T13:11:24.408+03:00 INFO [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy , running 2 parallel message handlers.
2019-03-06T13:11:24.449+03:00 INFO [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout=‘30000 ms’, maxWaitQueueSize=5000}
2019-03-06T13:11:24.541+03:00 INFO [cluster] No server chosen by ReadPreferenceServerSelector{readPreference=primary} from cluster description ClusterDescription{type=UNKNOWN, connectionMode=SINGLE, serverDescriptions=[ServerDescription{address=localhost:27017, type=UNKNOWN, state=CONNECTING}]}. Waiting for 30000 ms before timing out
2019-03-06T13:11:24.838+03:00 INFO [connection] Opened connection [connectionId{localValue:1, serverValue:20}] to localhost:27017
2019-03-06T13:11:24.854+03:00 INFO [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=REPLICA_SET_PRIMARY, state=CONNECTED, ok=true, version=ServerVersion{versionList=[4, 0, 6]}, minWireVersion=0, maxWireVersion=7, maxDocumentSize=16777216, roundTripTimeNanos=3674710, setName=‘rs0’, canonicalAddress=node01.local:27017, hosts=[node02.local:27017, node03.local:27017, node01.local:27017], passives=, arbiters=, primary=‘node01.local:27017’, tagSet=TagSet{}, electionId=7fffffff0000000000000001, setVersion=3, lastWriteDate=Wed Mar 06 13:11:23 EET 2019, lastUpdateTimeNanos=11093256202569}
2019-03-06T13:11:24.870+03:00 INFO [connection] Opened connection [connectionId{localValue:2, serverValue:21}] to localhost:27017
node02 graylog.log file
2019-03-06T13:13:59.534+03:00 INFO [LogManager] Logs loading complete.
2019-03-06T13:13:59.534+03:00 INFO [KafkaJournal] Initialized Kafka based journal at /data/graylog/journal
2019-03-06T13:13:59.573+03:00 INFO [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy , running 2 parallel message handlers.
2019-03-06T13:13:59.608+03:00 INFO [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout=‘30000 ms’, maxWaitQueueSize=5000}
2019-03-06T13:13:59.701+03:00 INFO [cluster] No server chosen by ReadPreferenceServerSelector{readPreference=primary} from cluster description ClusterDescription{type=UNKNOWN, connectionMode=SINGLE, serverDescriptions=[ServerDescription{address=localhost:27017, type=UNKNOWN, state=CONNECTING}]}. Waiting for 30000 ms before timing out
2019-03-06T13:13:59.743+03:00 INFO [connection] Opened connection [connectionId{localValue:1, serverValue:25}] to localhost:27017
2019-03-06T13:13:59.758+03:00 INFO [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=REPLICA_SET_SECONDARY, state=CONNECTED, ok=true, version=ServerVersion{versionList=[4, 0, 6]}, minWireVersion=0, maxWireVersion=7, maxDocumentSize=16777216, roundTripTimeNanos=3617725, setName=‘rs0’, canonicalAddress=node02.local:27017, hosts=[node02.local:27017, node03.local:27017, node01.local:27017], passives=, arbiters=, primary=‘node01.local:27017’, tagSet=TagSet{}, electionId=null, setVersion=3, lastWriteDate=Wed Mar 06 13:13:58 EET 2019, lastUpdateTimeNanos=6793303396622}
2019-03-06T13:13:59.797+03:00 INFO [connection] Opened connection [connectionId{localValue:2, serverValue:26}] to localhost:27017
2019-03-06T13:14:00.178+03:00 INFO [cluster] No server chosen by WritableServerSelector from cluster description ClusterDescription{type=REPLICA_SET, connectionMode=SINGLE, serverDescriptions=[ServerDescription{address=localhost:27017, type=REPLICA_SET_SECONDARY, state=CONNECTED, ok=true, version=ServerVersion{versionList=[4, 0, 6]}, minWireVersion=0, maxWireVersion=7, maxDocumentSize=16777216, roundTripTimeNanos=3617725, setName=‘rs0’, canonicalAddress=node02.local:27017, hosts=[node02.local:27017, node03.local:27017, node01.local:27017], passives=, arbiters=, primary=‘node01.local:27017’, tagSet=TagSet{}, electionId=null, setVersion=3, lastWriteDate=Wed Mar 06 13:13:58 EET 2019, lastUpdateTimeNanos=6793303396622}]}. Waiting for 30000 ms before timing out
2019-03-06T13:14:30.192+03:00 INFO [cluster] No server chosen by WritableServerSelector from cluster description ClusterDescription{type=REPLICA_SET, connectionMode=SINGLE, serverDescriptions=[ServerDescription{address=localhost:27017, type=REPLICA_SET_SECONDARY, state=CONNECTED, ok=true, version=ServerVersion{versionList=[4, 0, 6]}, minWireVersion=0, maxWireVersion=7, maxDocumentSize=16777216, roundTripTimeNanos=1199113, setName=‘rs0’, canonicalAddress=node02.local:27017, hosts=[node02.local:27017, node03.local:27017, node01.local:27017], passives=, arbiters=, primary=‘node01.local:27017’, tagSet=TagSet{}, electionId=null, setVersion=3, lastWriteDate=Wed Mar 06 13:14:28 EET 2019, lastUpdateTimeNanos=6823420143388}]}. Waiting for 30000 ms before timing out
My questions are ;
  • Why cant make it up ?
  • Why I’m always seeing in the log files that the mongo is connecting locally instead of cluster on all of my servers ?
Any help ?
Thank you.
Mehmet
Dear all, I’m trully sorry to take your time. I have found the problem.
My graylog.conf file has this line ;
Actually it should be like this ;
mongodb_uri = mongodb://node01.local:27017,node02.local:27017,node03.local:27017/graylog?replicaSet=rs0
I forgot to add “mongodb_uri =” part. Copy / Paste issues from text editor :slight_smile:
Best regards.
Mehmet
