Hi Folks,
Today I implement Graylog monitoring with Zabbix, however, it could not succeed. I used zabbix-graylog-monitoring of bezarsnba at github & share.graylog.org.
I got an error:
"graylog-srv-02:graylog.proc.buffer[ProcessBufferProcessor.processTime,m5_rate]" became not supported: Unsupported item key.
I don’t know if you already installed this before. So I would like to post here and hope someone can help me.
Here is my system:
- Graylog 3.0
- Zabbix 4.0
- Python 3.5/ 3
- Ubuntu 16.04 LTS
I tightly followed your instruction, however, this is not the same version of Zabbix and Python, then I got any issue [not supported] with following templates:
- GrayLog: Filter execution Time(FIltered OutMessages) 5min
- GrayLog: Filter execution Time(Incoming Messages) 5min
- GrayLog: Filter execution Time(Outgoing Message) 5min
- GrayLog: Filter execution Time(Process Time) 5min
- GrayLog: Internal Log Message Error 5 min
- GrayLog: Internal Log Message Fatal 5 min
- GrayLog: Internal Log Message Trace 5 min
- GrayLog: Internal Log Message Warn 5 min
- GrayLog Journal Size
And what did I implement
sky@zabbix4-srv-01:/opt/packages$ sudo git clone https://github.com/bezarsnba/zabbix-graylog-monitoring.git
sky@zabbix4-srv-01:/opt/packages$ cd zabbix-graylog-monitoring/
sky@zabbix4-srv-01:/opt/packages/zabbix-graylog-monitoring$ sudo mkdir /etc/zabbix/scripts
sky@zabbix4-srv-01:/opt/packages/zabbix-graylog-monitoring$ sudo chmod +x /etc/zabbix/scripts/monitoring-graylog.py
sky@zabbix4-srv-01:/etc/zabbix/scipts$ python3
python3 python3.5 python3.5m python3m
sky@zabbix4-srv-01:/etc/zabbix/scipts$ python3.5 monitoring-graylog.py lldgraylognode
"data":[
"{#NODEID}":"74654950-8fa7-4b2f-ac1f-afe08d2d1b02"
sky@zabbix4-srv-01:/etc/zabbix/scipts$ grep Include /etc/zabbix/zabbix_agentd.conf
### Option: Include
# Include=
Include=/etc/zabbix/zabbix_agentd.d/*.conf
# Include=/usr/local/etc/zabbix_agentd.userparams.conf
# Include=/usr/local/etc/zabbix_agentd.conf.d/
# Include=/usr/local/etc/zabbix_agentd.conf.d/*.conf
sky@zabbix4-srv-01:/etc/zabbix/scipts$ sudo cp /opt/packages/zabbix-graylog-monitoring/user_parameter_graylog.conf /etc/zabbix/zabbix_agentd.d/
sky@zabbix4-srv-01:/etc/zabbix$ zabbix_get -s 10.30.3.117 -k graylog.discovery.node
"data":[
sky@zabbix4-srv-01:/etc/zabbix/zabbix_agentd.d$ zabbix_get -s 10.30.3.117 -k graylog.cluster.status['74654950-8fa7-4b2f-ac1f-afe08d2d1b02',lb_status]
alive
Thank you so much!
