Monitoring Docker Containers with Graylog Monitoring
Hello today I use docker-compose for a number of services.
I would like to collect the container log with graylog, but it is not working.
I already have graylog running according to the following documentation:
http://docs.graylog.org/en/latest/pages/installation/docker.html
On the server where the containers are, I create the following file:
I came /etc/docker/daemon.json
“log-driver”: “gelf”,
“log-opts”: {
“gelf-address”: “udp: //x.x.x.x: 514”
Common servers when changing rsyslog I get the log in graylog normally, for the container this does not happen.
In system / inputs I have created a Geft UDP to provide, but not solve.
What would be the correct configuration?
The Docker GELF logging driver is using the GELF logging message format.
Using port 514/udp indicates that you’re using a Syslog UDP input in Graylog, which won’t work.
Either you’ll have to switch to the Docker Syslog logging driver or you’ll have to start a GELF UDP input in Graylog.
