Monitor Graylog Stream Output Health on Graylog 3.X
Hi everyone,
i’m actually investigate a way to monitor / cheack health of Graylog Stream Output.
Use case:
Graylog actually forwarding event to another graylog in GELF format, sometime the log flow stop and it take time to restart. On graylog web UI it’s hard to check statistic / KPI about output.
Any advice will be appreciate :wink:
Have a good day !
check the GELF input on the remote Graylog … that is easier. Optional, use the Graylog Forwarder.
http://docs.graylog.org/en/3.0/pages/integrations.html
Hi @jan, thanks for you help.
I havent an entreprise licence. Cheking Graylog inpt could be done throught the API ?
