I show in open-source-vs-enterprise page on the Graylog website:
Data Forwarder:
- Open source : KO
- Enterprise : OK
Is it this GELF output feature (system/outputs) restricted?
In 3.1 version, I can create a GELF output for example.
In 3.3, is it restricted ?
jan
(Jan Doberstein)
2
he @celine
you might want to click on the description what the data forwarder is … or check the documentation: https://docs.graylog.org/en/3.3/pages/integrations/forwarder.html#forwarder
GELF outputs are not the data forwarder.
system
(system)
Closed
3
