MongoDB adapter missing in Lookup Tables configuration
“MongoDB” Data Adapter Type is missing while creating Data Adapter for Lookup Tables
  • OS Information:
    Rocky Linux release 9.1 (Blue Onyx)
  • Package Version:
    Graylog 5.0.5+d61a926 (Eclipse Adoptium 17.0.6 on Linux 5.14.0-162.6.1.el9_1.x86_64)
Searched the documentation and the internet…
Why there is no MongoDB Adapter in my dropdown list? According to the documentation it should be there. All(?) other adapters are listed (CSV, DSV, GeoIP, HTTPJsonPath,…).
Do I need a plugin? Or is it missing in Graylog Open, anyway?
Thanks a lot for all hints!
Its an enterprise feature, so it wont be an option if you dont have a license applied.
