I’m trying to enable Beats input HTTPS with Graylog 2.4 on MetricBeats, and use mutual TLS with client certificates uploaded to Graylog. It works specifying the file path of a specific client cert. But with the directory option, receiving error:
Caused by: java.io.IOException: Short read of DER length
When I edit the Beats input plugin, here:
System --> Inputs
Stop Input
More Actions --> Edit Input
Scroll down to input field: TLS Client Auth Trusted Certs(optional)
When I input: /etc/openssl
It doesn’t work.
When I input: /etc/openssl/clientcert.cert
It works. It says that directory or file can be used, “TLS Client Auth Trusted Certs (File or Directory)”
I had tried to communicate this in the first post, the error is “short read of DER length.”
I’m on Ubuntu 16.04, and logfile is “/var/log/graylog-server/server.log”
Here is copy and paste from relevant log:
`java.security.cert.CertificateException: Unable to initialize, java.io.IOException: Short read of DER length
at sun.security.x509.X509CertImpl.(X509CertImpl.java:198) ~[?:1.8.0_151]
2018-02-04T15:57:00.889Z WARN [AbstractNioSelector] Failed to initialize an accepted socket.
at sun.security.provider.X509Factory.parseX509orPKCS7Cert(X509Factory.java:471) ~[?:1.8.0_151]
at sun.security.provider.X509Factory.engineGenerateCertificates(X509Factory.java:356) ~[?:1.8.0_151]
at java.security.cert.CertificateFactory.generateCertificates(CertificateFactory.java:462) ~[?:1.8.0_151]
at org.graylog2.plugin.inputs.transports.util.KeyUtil.loadCertificates(KeyUtil.java:91) ~[graylog.jar:?]
at org.graylog2.plugin.inputs.transports.util.KeyUtil.loadCertificates(KeyUtil.java:103) ~[graylog.jar:?]
at org.graylog2.plugin.inputs.transports.util.KeyUtil.initTrustStore(KeyUtil.java:73) ~[graylog.jar:?]
at org.graylog2.plugin.inputs.transports.AbstractTcpTransport$1.createSslEngine(AbstractTcpTransport.java:199) ~[graylog.jar:?]
at org.graylog2.plugin.inputs.transports.AbstractTcpTransport$1.call(AbstractTcpTransport.java:186) ~[graylog.jar:?]
at org.graylog2.plugin.inputs.transports.AbstractTcpTransport$1.call(AbstractTcpTransport.java:182) ~[graylog.jar:?]
at org.graylog2.plugin.inputs.transports.NettyTransport$1.getPipeline(NettyTransport.java:110) ~[graylog.jar:?]
at org.jboss.netty.channel.socket.nio.NioServerBoss.registerAcceptedChannel(NioServerBoss.java:134) [graylog.jar:?]
at org.jboss.netty.channel.socket.nio.NioServerBoss.process(NioServerBoss.java:104) [graylog.jar:?]
at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:337) [graylog.jar:?]
at org.jboss.netty.channel.socket.nio.NioServerBoss.run(NioServerBoss.java:42) [graylog.jar:?]
at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108) [graylog.jar:?]
at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42) [graylog.jar:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_151]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_151]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_151]
at sun.security.util.DerInputStream.getLength(DerInputStream.java:582) ~[?:1.8.0_151]
at sun.security.util.DerValue.(DerValue.java:258) ~[?:1.8.0_151]
at sun.security.util.DerInputStream.getDerValue(DerInputStream.java:451) ~[?:1.8.0_151]
at sun.security.x509.X509CertImpl.parse(X509CertImpl.java:1784) ~[?:1.8.0_151]
at sun.security.x509.X509CertImpl.(X509CertImpl.java:195) ~[?:1.8.0_151]
That worked perfectly well. Thank you! I just created a new directory of /etc/openssl/clients and copied the one client generated public certificate into the directory. Re-started the plugin and specified that directory, and it worked. THANK YOU!
