Hi Guys,
I’m using Graylog 2.3 + Elasticsearch 5.5 and I would like to send the maltrail logs to Graylog.
Do I have to add Graylog Server IP to the maltrail configuration file?
Thanks a lot!
César
Hi Guys,
Thanks a lot!
César
What’s mailtrail, what types of logs does it produce, and how can you access these logs?
Hej @cesar.fabre
following this issue you can just forward the logs via Syslog/CEF to Graylog.
Configure a CEF Input in Graylog and put the Graylog IP and the Input Port into the configuration and everything should work.
