Lowercase field names?
I’ve been trying to figure out a clean way to force lowercase on all field names. So far, I haven’t found a way to capture/iterate through every field in a pipeline parser. Something like $message.* or a way to use value substitution would be fantastic.
I wish I could figure out something like:
rename_field($message.$field, lowercase(to_string($message.$field));
Any suggestions?
I could not imagine a way to make this work - currently. Sorry.
Yeah. That was the end result I found after pouring over available functions. You can see the use case when receiving a large amount of varied log sources using something like json though, right?
My current options are to manipulate the case before sending, which puts load on the log sources- when the parsing logic load is already designed to be after input in graylog.
