Parsing extractors
Hello everyone,
Microsoft 365 logs are sent from a collector to Graylog.
The logs arrive unformatted and the content of the “message” field is always in a different order. I would therefore have to create countless grok patterns.
An alternative is an Extracor. Here I get different fields with the corresponding value. The problem, however, is that I cannot rename the fields. The pipeline rule function “rename_field”, which I use for other streams, does not work here.
Translated with DeepL.com (free version)
  • OS Information: 6.0.1
    Example of a log:
    {“BrowserVersion”:“Value”,“UserType”:Value,“DeviceDisplayName”:“Value”,“RecordType”:Value,“Version”:Value,“Operation”:“Value”}
Various pipeline rules, Google
Do any of you have an idea how to solve the problem?
Isnt this just json that you can parse with the json functions in pipelines?
