Lots of cluster_block_exception indexing errors
Hi all,
I’m seening lots of these:
{“type”:“cluster_block_exception”,“reason”:“blocked by: [FORBIDDEN/12/index read-only / allow delete (api)];”}
The disk has free space.
If I run this:
sudo curl -XPUT -H “Content-Type: application/json” https://localhost:9200/_all/_settings -d ‘{“index.blocks.read_only_allow_delete”: null}’
I get this:
curl: (35) error:1408F10B:SSL routines:ssl3_get_record:wrong version number
Graylog 3.0.2 running as a VM.
Thanks,
Adam
Disregard. Seems I needed to specify “http” and not https.
Thanks.
