Loop over backlog in Notification body
I try to get a notification like:
{“src_ip”: [“1.1.1.1”, “2.2.2.2”, “3.3.3.3”], “dest_ip”: [“1.2.3.4”]}
I try to loop over backlog but I have 2 issues:
Firstly we can only loop over logs (messages) and not on a specific field.
For example I can’t loop over src_ip, I could only get something like {“messages”: [{“src_ip”: “1.1.1.1”, “dest_ip”: “1.2.3.4”}, {“src_ip”: “2.2.2.2”, “dest_ip”: “1.2.3.4”}]}
I would expect to loop as:
{“src_ip”: ${foreach backlog.message.fields.src_ip ip}"${ip}"${end}, }
Secondly I can’t remove the last coma in a loop.
${if backlog}{“messages”: [${foreach backlog message}{“src_ip”: ${message.fields.src_ip}${end}, ]}${end}
It would produce something like:
{“messages”: [{“src_ip”: “1.1.1.1”}, {“src_ip”: “2.2.2.2”}, ]}
You notice the last coma breaking the JSON format.
Do I miss something ?
I don’t find any documentaion on the notification language (if, foreach…)
Perhaps something here may help.
The documentation is incomplete. It only gives some examples, but it doesn’t explain the language in details.
From the documentation linked above I noticed this.
From this section here
As for how the language is explained in detail, not sure.
I might be able to give some examples but its hard to read your post above, perhaps using the markdown language would help and a example of what you trying to achieve would be great
Thank you for pointing to this documentation.
The page Java Minimal Template Engine explains all the possibility offered by this language.
I’m now able to fix my second issue: I can remove the last coma thanks to the special variable ${if last_item}.
So the last problem is I can’t loop over a specific field in the backlog such as:
{"src_ip": [${foreach backlog.fields.src_ip ip}"${ip}" ,${end}]}
which would produce something like:
{"src_ip": ["1.1.1.1", "2.2.2.2", "3.3.3.3"]}
Maybe something like this could work:
	"src_ip": [
		${foreach backlog log}
			${foreach log.fields field}
				${if field.key=src_ip}
					${if last_field}
						"${field.src_ip}"
					${else}
						"${field.src_ip}" ,
					${end}
				${end}
			${end}
		${end}
	"dest_ip": [
				${if field.key=dest_ip}
					${if last_field}
						"${field.dest_ip}"
					${else}
						"${field.dest_ip}" ,
					${end}
				${end}
			${end}
		${end}
It’s not very efficient but it works:
    	"src_ip": [
    					${if last_log}
    						"${field.value}"
    					${else}
    						"${field.value}" ,
    					${end}
    				${end}
    			${end}
    		${end}
    	"dest_ip": [
    					${if last_log}
    						"${field.value}"
    					${else}
    						"${field.value}",
    					${end}
    				${end}
    			${end}
    		${end}
