How to loop out src and dst in email notifications
Prerequisite:
1,Aggregation→Group by Field(s):src
2,Message Backlog:50
3,Search Query:dpt:137 AND act:deny AND src:(10.240.150.55 OR 10.240.174.24 OR 10.240.150.13)
4,Notifications→body Template:
${if backlog}
— [Backlog] ------------------------------------
Last messages accounting for this alert:
${foreach backlog message}
SourceAddress: ${message.fields.src}
DestinationIP: ${message.fields.dst}
Port: ${message.fields.dpt}
${end}
My problem is that the Backlog section of the received notification email contains other source address information (which meets the search criteria). But I only want the information of the src that issued the warning.
What are some ways to solve this problem。
Hey @yangkun.li
You can use the Search Query in alert/Event Definition.
Second option would be filter out the logs/messages that contain information of the src that issued the warning. Then route it to another stream. Attach your new stream to Event Definition and enable Aggregation of results reaches a threshold this will allow you to create Create Events for Definition to something like this if count() > 0 it should aleert you soon as that log/message hit the stream.
Third option would use a piepline and filter out what you need to be alerted on.
