Localhost Ncat: Connection refused
I just set up my Graylog server on AWS, and so far, I can access the WebUI, etc. However, I’m not able to even send a test message to Graylog. I set SELinux (CentOS 7 system) to permissive, I’m not running FirewallD, and my Lightsail firewall is allowing all TCP and UDP traffic my from my home’s IP.
Even when I try to connect from localhost, I get the following message:
echo "Hello Graylog, let's be friends." | nc -w 1 -u 127.0.0.1 9099
Ncat: Connection refused.
2020-08-11T14:54:19.660Z WARN  [ProxiedResource] Unable to call http://glog.mygreatserver.com:9000/api/system/metrics/multiple on node <d74bfe23-e7a3-4c11-85a2-4949820ca5aa>: connect timed out
2020-08-11T14:54:25.662Z WARN  [ProxiedResource] Unable to call http://glog.mygreatserver.com:9000/api/system/metrics/multiple on node <d74bfe23-e7a3-4c11-85a2-4949820ca5aa>: connect timed out
2020-08-11T14:57:40.025Z WARN  [LicenseChecker] License violation - Detected irregular traffic records
I also ran a port scan on the server
Port Scanning host: 23.17.127.191
	 Open TCP Port: 	22     		ssh
	 Open TCP Port: 	111    		sunrpc
	 Open TCP Port: 	9000   		cslistener
I’m not sure what I haven’t configured correctly, so any insights would be greatly appreciated!
Can you share more details about your environment? Since you’re sending it to localhost, then I assume you operate on the host where Graylog is running, so it’s not clear why you are referring to some firewalls and home IPs.
First, please show output of
lsof -Pni :9099
(assuming 9099 is your Input port, please share Input configuration also)
Then additionally I would check the following:
iptables-save
ip r
ip -c -br -4 a
Hi @zoulja, thanks for the reply.
Sorry for the confusion about the home IP, firewall, etc., I guess I was just trying to clarify my configuration.
I ran lsof -Pni :9099 as you recommended, and there was zero output.
Also, this is a CentOS 7.8 system, and I don’t believe I’m running iptables.
systemctl status iptables
Unit iptables.service could not be found.
Port is not listened and you didn’t provide requested information.
The end.
CentOS7 by default uses firewalld service, not iptables. So try to check firewalld:
sudo systemctl status firewalld.service
