Listen on UDP IPV4 Port 1514
My problem is when I run netstat and look at the open ports, all I see for Graylog is IPV6 UDP Ports. I’m trying to get IPv4 UDP port 1514 open for UDP syslog messages into graylog. I do have the INPUT created in graylog. This is on Ubuntu Server 20 using the Graylog Ubuntu docs to build Graylog.
I found this in the manual:
Problems with IPv6 vs. IPv4?
If your Graylog node refuses to listen on IPv4 addresses and always chooses for example a http_bind_address like :::9000 you can tell the JVM to prefer the IPv4 stack.
Add the java.net.preferIPv4Stack flag in your graylogctl script or from wherever you are calling the graylog.jar :
~$ sudo -u graylog java -Djava.net.preferIPv4Stack=true -jar graylog.jar
The above command is coming back with “usage: graylog []. so I’m missing something with getting the " java.net.preferIPv4Stack” added to the graylogctl script. The graylog.jar file is not readable so not sure where/what script I need to be editing.
What version of graylog are you using?
Did you manaully install Graylog or did you use a package installer?
I followed the Ubuntu Install Instructions found here:
https://docs.graylog.org/en/3.3/pages/installation/os/ubuntu.html#ubuntuguide
It was installed using the package installer per the instructions. It had me install version 3.3 - latest
Couple of quick points here:
  • 4.0.6 is the latest version of Graylog. If you’re installing 3.3.X, I assume you got to that version of the docs through a search of some sort.
  • You should be able to add the -Djava.net.preferIPv4Stack=true to the environment variable GRAYLOG_SERVER_JAVA_OPTS in /etc/default/graylog-server and restart Graylog to have it use IPv4 explicitly
Thank You!! That worked!
