a-ml
(a-ml)
1
Please need help.
I’ve created inputs in a new graylog installation and it seems to only listen on ipv6 not ipv4.
Can someone please help on making the application listen as well on IPv4?
]$ netstat -anp | grep 12201
(No info could be read for “-p”: geteuid()=1000 but you should be root.)
tcp6 0 0 :::12201 :::* LISTEN -
netstat -anp | grep 65514
udp6 0 0 :::65514 :::* -
regards,
AM
jan
(Jan Doberstein)
2
What OS did you use? Did you have a multi homed setup? Did you checked if the inputs really only listen on the ipv6?
a-ml
(a-ml)
3
I’m using CentOS.
NO, single homed.
Regards,
jan
(Jan Doberstein)
4
Did you notice the quote from the linked thread?
a-ml
(a-ml)
5
Hello Jan,
Didin’t noticed. Can you please point me out?
I’ve seen in another thread that we need to change some viriable on the system,
GRAYLOG_SERVER_JAVA_OPTS
located at /etc/sysconfig/graylog-server
but don’t know how.
Best regards,
AR
a-ml
(a-ml)
7
I’m aware of that, but I don’t see any tcp4 LISTEN port while issuing the netstat command.
Is there a way to only activate the application to LISTEN on TCPv4? If so, can you help me out?
Regards,
jan
(Jan Doberstein)
8
you might find the information in this thread helpful Ipv6 to Ipv4 help me
a-ml
(a-ml)
9
Hello Jan,
Thanks for all your help.
At the end I found that it was related to incompatibility between Elasticsearch 6 and Graylog
Regards,
