So, now that I got Graylog and Sidecar working, I think it’d be nice to try and SSL it with Certbot. My first thought was: follow the yellow brick road - but it didn’t worked, I think because nginx isn’t on the default path - is this correct?
So, my first question (I mean, second, since “is this correct?” was the first) would be: do you guys think it’d be easier if I started over, changing the testing grounds from the OVA to a properly built server, or should I try to fix Certbot manually?
