Seemingly after a recent update (maybe log4J) LDAP has failed. Test Server Configuration fails. This has worked for many months with no changes made.
OS Information: RHEL 8.x
Package Version: Graylog 4.2.3+553fadb
There was an error fetching a resource: Bad Request. Additional information: Null value (through reference chain: org.graylog.security.authservice.test.AutoValue_AuthServiceBackendTestRequest$Builder[âbackend_configurationâ]->org.graylog.security.authservice.$AutoValue_AuthServiceBackendDTO$Builder[âconfigâ]->org.graylog.security.authservice.backend.AutoValue_ADAuthServiceBackendConfig$Builder[âsystem_user_passwordâ])
false
We have a free Enterprise license. So far I have tried nothing. This has worked for months and started failing after the last Graylog update yesterday. Using the LDAP authentication wizard fails the Test Server Configuration showing the included message above. I didnât notice because my cookie had not expired until late today. I see a server.conf.rpmnew, but there is nothing there aside from the name/pass/server fields that require editing. The rest of the diffs are commented info.
I did a quick update in my Lab from version 4.2.2 to 4.2.3 using my Active directory user for Graylog.
Iâm not sure how you set up your LDAP but here is mine.
Iâll be back on it in the morning, but one difference is on mine Verify Certificate is checked. Although neither TLS or StartTLS are. Also pam/sssd also use LDAP and they still work. Totally different mechanisms of course.
The original error you posted suggests a null field associated with system_user_password. For the User DN, you can try using the full username such as Auth-account@mylocaldomain.tld
Also double check that your enterprise plugins are updated - you can use this command to check (I think)
yum list installed | grep -E ".*(elasticsearch|graylog|mongo).*"
The pam/sssd login uses LDAP, so LDAP works for pam.
Here is the full log for a failed login:
2021-12-16T13:18:24.508-05:00 ERROR [AESTools] Could not encrypt value.
java.security.NoSuchProviderException: No such provider: SunJCE
at javax.crypto.Cipher.getInstance(Cipher.java:596) ~[?:1.8.0_312]
at org.graylog2.security.AESTools.encrypt(AESTools.java:57) ~[graylog.jar:?]
at org.graylog2.security.encryption.EncryptedValueService.encrypt(EncryptedValueService.java:45) ~[graylog.jar:?]
at org.graylog2.security.realm.UsernamePasswordRealm.doGetAuthenticationInfo(UsernamePasswordRealm.java:92) ~[graylog.jar:?]
at org.graylog2.security.realm.UsernamePasswordRealm.doGetAuthenticationInfo(UsernamePasswordRealm.java:71) ~[graylog.jar:?]
at org.apache.shiro.realm.AuthenticatingRealm.getAuthenticationInfo(AuthenticatingRealm.java:571) ~[graylog.jar:?]
at org.apache.shiro.authc.pam.ModularRealmAuthenticator.doMultiRealmAuthentication(ModularRealmAuthenticator.java:225) ~[graylog.jar:?]
at org.apache.shiro.authc.pam.ModularRealmAuthenticator.doAuthenticate(ModularRealmAuthenticator.java:275) ~[graylog.jar:?]
at org.apache.shiro.authc.AbstractAuthenticator.authenticate(AbstractAuthenticator.java:198) ~[graylog.jar:?]
at org.apache.shiro.mgt.AuthenticatingSecurityManager.authenticate(AuthenticatingSecurityManager.java:106) ~[graylog.jar:?]
at org.apache.shiro.mgt.DefaultSecurityManager.login(DefaultSecurityManager.java:275) ~[graylog.jar:?]
at org.apache.shiro.subject.support.DelegatingSubject.login(DelegatingSubject.java:260) ~[graylog.jar:?]
at org.graylog2.shared.security.SessionCreator.create(SessionCreator.java:82) ~[graylog.jar:?]
at org.graylog2.rest.resources.system.SessionsResource.newSession(SessionsResource.java:142) ~[graylog.jar:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_312]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_312]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_312]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_312]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory.lambda$static$0(ResourceMethodInvocationHandlerFactory.java:52) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:124) [graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:167) [graylog.jar:?]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$TypeOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:219) [graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:79) [graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:469) [graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:391) [graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:80) [graylog.jar:?]
at org.glassfish.jersey.server.ServerRuntime$1.run(ServerRuntime.java:255) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:248) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:244) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:292) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:274) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:244) [graylog.jar:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:265) [graylog.jar:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:234) [graylog.jar:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:680) [graylog.jar:?]
at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:356) [graylog.jar:?]
at org.glassfish.grizzly.http.server.HttpHandler$1.run(HttpHandler.java:200) [graylog.jar:?]
at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:180) [graylog.jar:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_312]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_312]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_312]
2021-12-16T13:18:24.509-05:00 ERROR [UsernamePasswordRealm] Unhandled authentication error
java.lang.NullPointerException: Null value
at org.graylog2.security.encryption.AutoValue_EncryptedValue$Builder.value(AutoValue_EncryptedValue.java:96) ~[graylog.jar:?]
2021-12-16T13:18:24.510-05:00 INFO [SessionCreator] Invalid credentials in session create request. Actor: "urn:graylog:user:joe_user"
Hmmm I have seen a few things on how password_secret in server.conf is used for salting passwords⊠is that something that might have changed in your test configuration or maybe wonked in translation?
I donât have illegal key size, so not the same issue. Seems like the root cause is No such provider: SunJCE. I did more testing with a different AD account, same issue. Tried with TLS, same issue.
OK, so Iâm a nitwit. We had an audit last week and enabled FIPS mode on all Linux systems. Iâm REALLY confident this is what killed LDAP login. Probably SunJCE canât function in that cryptographic mode. I have not verified, but Iâm pretty sure that is the cause. Of course there is no reference to FIPS in Graylog documentation.
