Latest Graylog-datanode not secure url and Authentication finally failed
I have graylog-enterprise running using nginx proxy but its graylog-datanode in port 9200 has appearing not secure url and Authentication finally failed in web ui
  • OS Information: CentOS
  • Package Version: Stream 9
    Authentication finally failed for null from [IP host]
modify opensearch in config file location of datanode = unsolved
modify datanode config related to certificate and authentication = unsolved
Please help to assist me on what file path needs to modify/fix the authenticated finally failed and its not secured url ? or is that a normal running gui of graylog-datanode integrated opensearch?
What are you trying to do, because you arent supposed to be accessing datanode via the web, only thr main graylog server talks to it?
Hi @Joel_Duffield
Appreciate your response,
I’m trying to secure the web of datanode or do i need to secure it? Addionally, it appears Authentication finally failed its that a normal web interface of datanode? Please help thanks in advance :innocent:
There is no web interface of datanode just some api endpoints that only the graylog server talks to. As long as you went through preflight then that connection is already secured.
Hi @Joel_Duffield
Noted on this I have running graylog-server but how about the message on port 9200? it says authentication finally failed do I need to do something to be authenticated when I access the port?
Thanks in advanced :innocent:
When datanode is setup during preflight, it is setup to use certificates it generates as authentication, so the only way to access it is to generate a certificate for 3rd part access whixh yiu can do in the graylog UI
Hi @Joel_Duffield
Thank you for the info I think there’s nothing I can do on graylog-datanode web since it already managed by graylog-server
Have a nice day.
