JSON Results limited for 150 results per query
We’re using Graylog 2.2.2 and when I try to query the search/universal/relative rest API in a JSON format, I get “total_results”:11090 but the messages array contains only 150 entries.
I didn’t find anything in the documentation limiting results for only 150 entries but in the REST API browser, the ‘Response Content Type’ I can select is only ‘text/csv’
This is the full command I’m using:
curl -u USER:PASS -H ‘Accept: application/json’ -X GET http://GRAYLOG_SERVER_ADDRESS/api/search/universal/relative?query=log_level%3AERROR&range=86400&fields=message%2Cservice-name
Anyone know what I’m missing?
Thanks,
Tzahi
Please upgrade to the latest stable version of Graylog and check if the problem still exists in that version.
Thanks for the reply.
We’re currently unable to upgrade Graylog (some devops schedule issue).
I think that the problem is due to the fact that there are a lot of results and the data comes chunked.
I’m using multiple queries with a ‘limit’ and ‘offset’ parameters, but thought maybe there’s something I’m missing here.
Tzahi
