Issues with HTTPS and inputs
Graylog 5.0.11+30bdbfa on xxxxxxxx (Eclipse Adoptium 17.0.8 on Linux 5.15.0-1038-ibm)
Opensearch
I have configured 3 inputs
Some Linux in clear and Linux TLS and Windows TLS.
All working perfectly while on HTTP.
Then i am trying to upgrade to HTTPS certificate for the graylog server.
I followed the documentation provided by GL etc.
Still get into this problem.
When attempting to START INPUT it doesn’t go to green.
2023-09-21T15:25:37.345+02:00 ERROR [DecodingProcessor] Error processing message RawMessage{id=59f75c01-5882-11ee-b4ef-0200034690cd, messageQueueId=14531815, codec=gelf, payloadSize=81, timestamp=2023-09-21T13:25:37.344Z, remoteAddress=/10.13.200.106:52262}
com.fasterxml.jackson.core.JsonParseException: Unrecognized token 'IPfI0L': was expecting (JSON String, Number, Array, Object or token 'null', 'true' or 'false')
 at [Source: (String)"IPfI0L.�F=v��`w�^`P�\u007FOw�fH�$�D9D��]��WU\u000F��\u0007��0�&�?�����{8\u001D\u0019/���I�G�0\u001A����ya4��\u001A�8"; line: 1, column: 7]
        at com.fasterxml.jackson.core.JsonParser._constructError(JsonParser.java:2391) ~[graylog.jar:?]
        at com.fasterxml.jackson.core.base.ParserMinimalBase._reportError(ParserMinimalBase.java:745) ~[graylog.jar:?]
        at com.fasterxml.jackson.core.json.ReaderBasedJsonParser._reportInvalidToken(ReaderBasedJsonParser.java:2961) ~[graylog.jar:?]
        at com.fasterxml.jackson.core.json.ReaderBasedJsonParser._reportInvalidToken(ReaderBasedJsonParser.java:2939) ~[graylog.jar:?]
        at com.fasterxml.jackson.core.json.ReaderBasedJsonParser._matchToken(ReaderBasedJsonParser.java:2713) ~[graylog.jar:?]
        at com.fasterxml.jackson.core.json.ReaderBasedJsonParser._handleOddValue(ReaderBasedJsonParser.java:1986) ~[graylog.jar:?]
        at com.fasterxml.jackson.core.json.ReaderBasedJsonParser.nextToken(ReaderBasedJsonParser.java:802) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.ObjectMapper._readTreeAndClose(ObjectMapper.java:4703) ~[graylog.jar:?]
        at com.fasterxml.jackson.databind.ObjectMapper.readTree(ObjectMapper.java:3076) ~[graylog.jar:?]
        at org.graylog2.inputs.codecs.GelfCodec.decode(GelfCodec.java:130) ~[graylog.jar:?]
        at org.graylog2.shared.buffers.processors.DecodingProcessor.processMessage(DecodingProcessor.java:156) ~[graylog.jar:?]
        at org.graylog2.shared.buffers.processors.DecodingProcessor.onEvent(DecodingProcessor.java:94) [graylog.jar:?]
        at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:95) [graylog.jar:?]
        at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:49) [graylog.jar:?]
        at java.lang.Thread.run(Unknown Source) [?:?]
2023-09-21T15:25:37.345+02:00 ERROR [DecodingProcessor] Unable to decode raw message RawMessage{id=59f75c08-5882-11ee-b4ef-0200034690cd, messageQueueId=14531822, codec=gelf, payloadSize=470, timestamp=2023-09-21T13:25:37.344Z, remoteAddress=/10.13.200.106:52262} on input <64fdbbd30174cb5d796c2d4e>.
2023-09-21T15:25:37.345+02:00 ERROR [DecodingProcessor] Error processing message RawMessage{id=59f75c08-5882-11ee-b4ef-0200034690cd, messageQueueId=14531822, codec=gelf, payloadSize=470, timestamp=2023-09-21T13:25:37.344Z, remoteAddress=/10.13.200.106:52262}
com.fasterxml.jackson.core.JsonParseException: Unexpected character ('�' (code 65533 / 0xfffd)): expected a valid value (JSON String, Number, Array, Object or token 'null', 'true' or 'false')
 at [Source: (String)"��~3�\u0018��\u001F�\u001D�����\u001A}ʶٛ+��5��\u001E��r��p���+�-�\u0018]��ޗ\u0010\u0012�2�+�I�W�p�����-` kGp��y�\u000Cy��5YM\u0018�8\u0016;&�\u0008���*��k(?rr$5TpK��\u0013�\u0009A*��7��-�\u0017L�s�K��`E\u000B=F\u0001\u007F+&� �\u001F�q���p�z�v�0��e�\h\u0003���1I\u001A\u00184��b��\u0003�AHƇݲ�����۔Kz$��Fo� j��/���;Lq\u0005��VWU�a,�\u0018�\u0006��-�\�\u001Bbg\u001CxA��)
|Ǜ�A��v\u0011Zi�c��{� �GC�F�yj�Q��53\u001Aa�C�.*���I(1\u00025*v���V��È��8�c\>5z�t/F�\u001Ciϓ��<a���DG�w���%m����Y-R��덼���\u0013�[�(���1�X��\u0001~�h���\N�������\u000B\&})�y:]��BE�.8F\u0017y��\u0016򮬋��* ���Z�o�O�I�s�b�^o�����
K?�^\��b$�4�u�9�\u001F��4\u000E� \u0009�n����_��\u007F"; line: 1, column: 2]
        at com.fasterxml.jackson.core.base.ParserMinimalBase._reportError(ParserMinimalBase.java:735) ~[graylog.jar:?]
        at com.fasterxml.jackson.core.base.ParserMinimalBase._reportUnexpectedChar(ParserMinimalBase.java:659) ~[graylog.jar:?]
        at com.fasterxml.jackson.core.json.ReaderBasedJsonParser._handleOddValue(ReaderBasedJsonParser.java:2005) ~[graylog.jar:?]
2023-09-21T15:25:37.345+02:00 ERROR [DecodingProcessor] Error processing message RawMessage{id=59f75c00-5882-11ee-b4ef-0200034690cd, messageQueueId=14531814, codec=gelf, payloadSize=264, timestamp=2023-09-21T13:25:37.344Z, remoteAddress=/10.13.200.106:52262}
7<�e�\u0010��hh�V\u000F�<�<��V$�r��Y��\u0004:J-\u0007�\u0007�\u0016ā�Bp�\u001F0P\u0006'�\������ʚ���\u0014�y\u001E�tH{���w�m�%n����Y�㚗�\u001By�e�'B7�i�q͔c���\u0017\u0007�=�9�\u0006s>�\u0006R�_\u0017�\�bԕҜ����\u0017*ju���(*����e�-�W\u0006�����~+']�VR��\u0016��r��\u000B��\u0015�n,�����J�m��@�7���I��`���ni���_���o��/�x��VɎ�@\u0010�\u0015��1�����"; line: 1, column: 2]
2023-09-21T15:25:37.345+02:00 ERROR [DecodingProcessor] Error processing message RawMessage{id=59f75c05-5882-11ee-b4ef-0200034690cd, messageQueueId=14531819, codec=gelf, payloadSize=60, timestamp=2023-09-21T13:25:37.344Z, remoteAddress=/10.13.200.106:52262}
com.fasterxml.jackson.core.JsonParseException: Unexpected close marker '}': expected ']' (for root starting at [Source: (String)"}\��(���8��\u0010y\u0013\u0014��7N�8\u0009�"4�p�
Uu
A菆V�H�P��΃+fD�,�~��艣�Pb"; line: 1, column: 0])
Uu
A菆V�H�P��΃+fD�,�~��艣�Pb"; line: 1, column: 2]
        at com.fasterxml.jackson.core.base.ParserBase._reportMismatchedEndMarker(ParserBase.java:1073) ~[graylog.jar:?]
        at com.fasterxml.jackson.core.json.ReaderBasedJsonParser._closeScope(ReaderBasedJsonParser.java:2982) ~[graylog.jar:?]
        at com.fasterxml.jackson.core.json.ReaderBasedJsonParser.nextToken(ReaderBasedJsonParser.java:710) ~[graylog.jar:?]
This looks like a possibly mismatch of certificates configured, for example the input using a different cert than the client.
Are you having issues with only the GELF UDP input? Was it working previously and then stopped working? Did anything happen that caused it to stop working?
As far as I can tell Gelf UDP does not support TLS and does not provide options to use TLS.
What agent/collector are you using to send logs to graylog?
I have 3 inputs.
A Linux one without TLS - plain
A Windows one with TLS
A Linux one with TLS
all theree were working flawless before it started to move the graylog server from http to https.
still can’t figure out this one :frowning:
log file tail
�)8y%`\u0003\u0012\u0007~\u001C�7�yQ2�\u000Bğ��\u0010Br<*t\u001E�:��\u0016\u000CZ���h)b���#~o\u001Bw\u0019\u001B=@O���8.�y��UƯ\u0008[�9�\u000BN/+=85��b��,�����\u000F�\u000EQ\u0018�"�s!“,۬�Y��0�e\u0007~r��n\u001C�\u0016”\u0012C�\u0009�z�L�I��\u0006\u0014��\u0018�Qۖ�n�/�\u0001��2Կ�67�\u0019|c�\u001BQZ\u0011�"�m\u0014�\u0012a\u0009J6�1�Q\u0011��\u0007�8O��nN��\u0018q�t\u00153\u001A1Hܽ\u001F�\u001C��\u0014�b3j�n�\u0014\u007F�\u0001��ٿx��R�n� \u0010�\u0015�:�"; line: 1, column: 2]
2023-09-25T14:01:32.147+02:00 ERROR [DecodingProcessor] Error processing message RawMessage{id=44723d20-5b9b-11ee-b216-0200034690cd, messageQueueId=40946894, codec=gelf, payloadSize=354, timestamp=2023-09-25T12:01:32.146Z, remoteAddress=/10.13.200.101:51698}
com.fasterxml.jackson.core.JsonParseException: Unexpected character ('' (code 92)): expected a valid value (JSON String, Number, Array, Object or token ‘null’, ‘true’ or ‘false’)
�{\u001CxAH�)\u0009��\u001FŞ�\u000B���F��4��׆V�X�P�#ơ��2a�\u0003���<I�g8�\u00030�l\u0007�(x!�9\u000C8h\u0004�����\u0081�b��9�^PY/�3U\u000Em�tP\u0017��va↌n0��"�����O�,����:�2a�v,5��r\u0005_B�5l@�%l �\u0002v\u0001p\u0007��.�fA���\u001B)�$�OF�28V\u001AeE5�y�����z\u000C����9�VP�p��8�9V����/-�±][:y��\u0015\u0019[,*Au���h:\u001CE�\u0019�_0%~���y��?�g.\u001Dx��R]k�0\u0010�+B�q��ԍ�Qw���&��"; line: 1, column: 2]gtFw\u007F�w^\u0005Z\u0017eΗ��uΖUYT�\u0012�w\u0013ظ=\u000C�
after days of digging.
The KEY for the cer was in ".key’ instead of “.pem” as per the new 5.x HTTPS documentation.
I took my cookbook form the 4.3 where everything worked great and applied those steps i knew it worked with.
All is ok now.
Damn s*!t
I’m glad you worked your way through it. Thank you for coming back to close the loop for future users in a similar position.
