Cannot create input with https enabled
I am able to create GELF inputs when using http only but when I add https I get the below error. I asusme the error is the certs are not in the java keystore but Im not sure why the inport didnt work. The error message doesnt give me much to go on though. Is there a more descriptive log that might point what the issue is? Or any other suggestions would be appreciated!
2020-03-31T12:04:53.981Z WARN  [UdpTransport] receiveBufferSize (SO_RCVBUF) for input GELFUDPInput{title=FS1, type=org.graylog2.inputs.gelf.udp.GELFUDPInput, nodeId=null} (channel [id: 0x336b3172, L:/127.0.0.1:12201]) should be 262144 but is 425984.
2020-03-31T12:08:00.837Z WARN  [ProxiedResource] Unable to call https://172.20.82.132:9000/api/system/inputstates on node <95cfc9a2-3b2f-449f-b7b9-f386261e415b>
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
        at sun.security.ssl.Alerts.getSSLException(Alerts.java:192) ~[?:1.8.0_242]
        at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1946) ~[?:1.8.0_242]
        at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:316) ~[?:1.8.0_242]
        at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:310) ~[?:1.8.0_242]
        at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1639) ~[?:1.8.0_242]
        at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:223) ~[?:1.8.0_242]
        at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1037) ~[?:1.8.0_242]
        at sun.security.ssl.Handshaker.process_record(Handshaker.java:965) ~[?:1.8.0_242]
        at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1064) ~[?:1.8.0_242]
        at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1367) ~[?:1.8.0_242]
        at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1395) ~[?:1.8.0_242]
        at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1379) ~[?:1.8.0_242]
        at okhttp3.internal.connection.RealConnection.connectTls(RealConnection.java:318) ~[graylog.jar:?]
        at okhttp3.internal.connection.RealConnection.establishProtocol(RealConnection.java:282) ~[graylog.jar:?]
        at okhttp3.internal.connection.RealConnection.connect(RealConnection.java:167) ~[graylog.jar:?]
        at okhttp3.internal.connection.StreamAllocation.findConnection(StreamAllocation.java:257) ~[graylog.jar:?]
        at okhttp3.internal.connection.StreamAllocation.findHealthyConnection(StreamAllocation.java:135) ~[graylog.jar:?]
        at okhttp3.internal.connection.StreamAllocation.newStream(StreamAllocation.java:114) ~[graylog.jar:?]
        at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:42) ~[graylog.jar:?]
        at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:147) ~[graylog.jar:?]
        at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:121) ~[graylog.jar:?]
        at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:126) ~[graylog.jar:?]
        at org.graylog2.rest.RemoteInterfaceProvider.lambda$get$0(RemoteInterfaceProvider.java:61) ~[graylog.jar:?]
        at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:200) ~[graylog.jar:?]
        at okhttp3.RealCall.execute(RealCall.java:77) ~[graylog.jar:?]
        at org.graylog2.shared.rest.resources.ProxiedResource.lambda$getForAllNodes$0(ProxiedResource.java:78) ~[graylog.jar:?]
        at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_242]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_242]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_242]
        at java.lang.Thread.run(Thread.java:748) [?:1.8.0_242]
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
        at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:450) ~[?:1.8.0_242]
        at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:317) ~[?:1.8.0_242]
        at sun.security.validator.Validator.validate(Validator.java:262) ~[?:1.8.0_242]
        at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:330) ~[?:1.8.0_242]
        at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:237) ~[?:1.8.0_242]
        at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:132) ~[?:1.8.0_242]
        at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1621) ~[?:1.8.0_242]
        ... 35 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
        at sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:141) ~[?:1.8.0_242]
        at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:126) ~[?:1.8.0_242]
        at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:280) ~[?:1.8.0_242]
        at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:445) ~[?:1.8.0_242]
        ... 35 more
he @eatyourpeas747
we have this part in the documentation: https://docs.graylog.org/en/3.2/pages/secure/sec_graylog_beats.html
that can be used as guidance what todo - if you followed the steps and are stuck at some point, please describe what you have done and where you are stuck.
