Hi there, I just upgraded from Graylog version 3.1.4 to 3.3.5, I noticed that views and dashboards are unified now, but when I go to the dashboard tab it is showing “loading view” seems like it is in a loop, I found this previous topic with the same issue Issue with Dashboard after upgrading from 3.1 to 3.2 , Im not sure which is the interval value that I need to fix in my document…
As always.I will appreciate your comments in advance.
