Solution to Dashboard issue after 3.2 upgrade
I saw the following posted about that this, but didn’t appear to be an additional details the post went stale.
Like the last user to comment, I was curious about the what needs to be done to the fix this issue. I would like to keep my dashboard so remove the view documents is not an option. I have been using the Robo3T tool to look at my MongoDB documents. I have been going through the view documents and see some interval values set to the following:
"config" : {
    "interval" : {
        "type" : "auto",
        "scaling" : null
What is not clear is what is the “wrong” interval value and what should it be done to fix it. Any information to solve this issue would be useful. Thanks!
Hi @jamiebuxxx,
I am sorry my previous description was not quite helpful :frowning_face:
I hope I can be clearer now. In your mongo db should be a view which has a time row bucket config like
this:
"config" : {
    "interval" : {
        "type" : "timeunit",
        "timeunit" : null
Where time unit can be anything. What it should be is like this:
"config" : {
    "interval" : {
        "scaling" : "1h"
I hope this helps. Let me know otherwise, and we try to fix it.
Best regards,
Konrad
@konrad Thanks for the update. I did see quite a few of those null values when looking at the views. Should I just remove the null values? I wasn’t able to edit them from Robo3T and I don’t have the most experience with MongoDB outside of the Graylog setup. I think we will need to some more help with this one! :slight_smile:
In the meantime, I had a backup of the MongoDB that was running 3.1 and we just rolled back so users have their dashboards. I have a copy of the MongoDB in question(the 3.2 version), so we can do some testing on that if you have some commands/scripts you would like for us to try.
Thanks!
