In my case,
I’m trying to iframe a graylog layout, and wondering is that possible to login into graylog
by URL like " http://localhost:9000?username=admin&password=admin " ?
I have not seen anything like that - might go against clear text password security protocol… so I would guess not… Others are welcome to chime in…
I’m thinking to use the tokens for users you can generate. But I don’t know if they fit this szenario.
Unless you found a good way to obfuscate the information and make it really secure, this would leave your instance open to basic hacking techniques.
well,
I switch it to base on remote Kibana to deal with it, so problem solved : P
