Hi all,
i am trying to support the grylog’s opensource but i am encountering some problems installing the needed environment for the server side.
I have cloned master branch using graylog-project cli tool and ran maven compile using jdk 17 (it failed using any other version stating 17 is the required one.) but when i am running the build i get an error stating skd 17 does not support the source version 1.5 :
"java: error: release version 5 not supported
Module graylog-plugin-threatintel SDK 17 does not support source version 1.5.
Possible solutions:
- Downgrade Project SDK in settings to 1.5 or compatible. Open project settings.
- Upgrade language version in Maven build file to 17. Update pom.xml and reload the project.
the maven comiler source is set to 17.
when i try to run it with 1.5 it cant run the code to to it being written for a more advanced version (for example it uses the diamond operator)
futhermore, while it hasn’t crashed on them yet, i have some unmet dependencies in the code that the compile did not download
should I have gotten them from the compile even though it finished succesfully?
