Ponet
(Jesse Hills)
January 10, 2023, 3:32pm
#1
While going over the Ubuntu installation guide, I noticed that the install instructions for Graylog are missing in the Ubuntu installation guide
The hint header gives the command installing /just/ the graylog-server package but, there is definitely a codeblock section missing from above the hint.
The link to the .deb is missing along with installation commands.
I believe the install packages for Ubuntu and Debian are the same so, a copy-paste from the Debian installation guide should suffice.
Ponet
(Jesse Hills)
January 10, 2023, 4:00pm
#2
Update, the debian installation instructions seem to be incorrect.
The repository deb file supplied in the installation guide returns an HTTP 404.
https://packages.graylog2.org/repo/packages/graylog-4.4-repository_latest.deb
Looking at https://packages.graylog2.org/packages - The latest repository DEB file is version 4.3.
gsmith
(GSmith)
January 10, 2023, 11:40pm
#3
Hey
I also have the same issue. @dscryber can you check this out?
