Installation graylog ova
I have a question about the installation of Graylog. I would like to use the ova file for installation. However, I saw in your documentation that "the Graylog appliance is not created to provide a production-ready solution, it is designed to provide a quick and easy way to try the software itself without losing time to install Graylog and its server components. " I want to implement the Graylog solution within the production infrastructure.
thank you in advance
Then you shouldn’t use the OVA (or AMI) but use a different method of installation, which allows for more customization of the whole setup:
http://docs.graylog.org/en/2.4/pages/installation.html
The installation of Graylog with ova file, it’s just for have a test appliance ?
Elasticsearch version 5.6.9, it’s good for Graylog 2.4.5 ?
It’s a full-fledged installation with limited customizability which we don’t recommend to use in production.
Yes, see http://docs.graylog.org/en/2.4/pages/configuration/elasticsearch.html and http://docs.graylog.org/en/2.4/pages/installation.html#system-requirements.
thanks for the informations
