I need to generate an alert on the indexer failure count. I found via api “api/system/metrics”, these metrics that do not reflect the actual number of indexer failures:
The thing is , those are found in the stream called Processing and Indexing Failures, you can create a widget for that stream and perhaps be able to the show “count” from you picture you posted, but any more details I would look into Grafana or if you under 2 Gb a day it free then try out the Operation/enterprise license.
