Index error in pipeline rule
I have this rule and it works but I’m also still getting errors with it, lol, despite it working
rule "ParseAndLookupMACVendor"
  has_field("source_mac")
  set_field("source_mac_vendor", "unknown");
  let s = split(":", to_string($message.source_mac));
  let prefix0 = concat(to_string(s[0]), ":");
  let prefix1 = concat(to_string(s[1]), ":");
  let macprefix0 = concat(to_string(prefix0), to_string(prefix1));
  let macprefix = concat(to_string(macprefix0), to_string(s[2]));
  let macvendor = lookup_value("mac-vendor-csv", macprefix);
  set_field("source_mac_vendor", macvendor);
Error:
(Error: In call to function 'to_string' at 8:23 an exception was thrown: index (1) must be less than size (1))
try putting quotes on your index numbers? Total guess…
EDIT: Don’t. I was wrong. Ignore that part.
  let prefix0 = concat(to_string(s["0"]), ":");
  let prefix1 = concat(to_string(s["1"]), ":");
  let macprefix = concat(to_string(macprefix0), to_string(s["2"]));
or… source_mac perhaps has something other than a MAC in it… You can put in:
debug(concat("+++ source_mac: ",to_string($message.source_mac)));
and watch the log files to see what your actual source_mac is coming across as.
~or~
perhaps you can make sure you have a MAC in the when/then
  has_field("source_mac") &&
  regex ("^(?:(?:[0-9A-Fa-f]{2}(?=([-:]))(?:\1[0-9A-Fa-f]{2}){5}))$", to_string($message.source_mac)) == ""
Yeah, annoying isn’t it?
  1. Caused Expected type Long but found String when indexing and wouldnt let me save the rule.
  2. Ran into issues with another rule I have that looks for randomized MAC’s.
Just ignore my unresearched and poor suggestion to put quotes in there. :roll_eyes: I don’t see anything wrong with how split() is being used - that suggests the error is because you have something other than a MAC coming in for source_mac If validating the MAC causes errors elsewhere… doesn’t that mean that you have non MAC things coming through that would cause an error here? :crazy_face:
here is an alternative rule - grab the first 8 char, look them up, if they don’t exist default the result to “unknown” and set the field as such.
  let macprefix = substring(to_string($message.source_mac),0,8);
  let macvendor = lookup_value("mac-vendor-csv", macprefix,"unknown");
That worked so much better with my next rule was to test if the MAC was randomized or not.
I really appreciate your help.
Mark it as the answer for future searches! Hopefully they will ignore my previous bad advice! :stuck_out_tongue:
